跳转到主内容
Shark Rocket Professional Floor Hose Replacement
你所需要的
  1. Shark Rocket Professional Floor Hose Replacement, Floor Hose: 步骤 1 中的图像 1,2 Shark Rocket Professional Floor Hose Replacement, Floor Hose: 步骤 1 中的图像 2,2
    • Look at the side of your vacuum.
    • Identify the button that says "Floor Nozzle."
    • Press this button and remove the main body of the vacuum.
  2. Shark Rocket Professional Floor Hose Replacement: 步骤 2 中的图像 1,3 Shark Rocket Professional Floor Hose Replacement: 步骤 2 中的图像 2,3 Shark Rocket Professional Floor Hose Replacement: 步骤 2 中的图像 3,3
    • Look at the bottom of the Floor Nozzle.
    • Use a coin to turn the orange locking dials counter-clockwise.
    • If you are unsure, follow the arrows when turning the orange dials because the labeling is confusing.
  3. Shark Rocket Professional Floor Hose Replacement: 步骤 3 中的图像 1,1
    • Use your fingers to pull open the panel locked by the orange mechanism.
    • If there is debris stuck in the tube, use a long, thin object to remove it.
结论
2等其他人完成本指南。
Brad Iglesia
于01/24/18注册
316 声望
创作了2篇指南
团队
Cal Poly, Team S18-G6, Livingston Winter 2018 Cal Poly, Team S18-G6, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 43
总计 4,852
