跳转到主内容
Shark Rocket Powerhead AH401 Motor Replacement
你所需要的
  1. Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: 步骤 1 中的图像 1,3 Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: 步骤 1 中的图像 2,3 Shark Rocket Powerhead AH401 Motor Replacement, Brushroll: 步骤 1 中的图像 3,3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 2 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 2 中的图像 2,2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motor Replacement, Back Panel Screws: 步骤 3 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement, Back Panel Screws: 步骤 3 中的图像 2,2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  4. Shark Rocket Powerhead AH401 Motor Replacement, Filter Grille: 步骤 4 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement, Filter Grille: 步骤 4 中的图像 2,2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 5 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 5 中的图像 2,2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  6. Shark Rocket Powerhead AH401 Motor Replacement, Belt: 步骤 6 中的图像 1,1
    • Remove the four screws by rotating counter-clockwise:
    • One 12 mm screw with a T10 Torx screwdriver
    • Three 14 mm screw with a T15 Torx screwdriver
  7. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 7 中的图像 1,3 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 7 中的图像 2,3 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 7 中的图像 3,3
    • Remove the grey filter plate by simply lifting upward.
    • Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 8 中的图像 1,1
    • Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  9. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 9 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 9 中的图像 2,2
    • Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
  10. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 10 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 10 中的图像 2,2
    • Remove the motor compartment panel by lifting up and away from the device.
  11. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 11 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 11 中的图像 2,2
    • Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
  12. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 12 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 12 中的图像 2,2
    • Disconnect the motor side panel by lifting the motor and panel up and out.
    • This step may require some wiggling to loosen the panel before it becomes free.
  13. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 13 中的图像 1,1
    • Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
    • This screw allows the side panel to be removed.
  14. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 14 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 14 中的图像 2,2
    • Remove the side panel by pulling the panel out and away from the motor.
    • The side panel is connected with clips which connect near the brushroll axle.
  15. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 15 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 15 中的图像 2,2
    • Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
    • The screws only need to be loosened in order to free the belt.
  16. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 16 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 16 中的图像 2,2
    • Remove the belt by pulling the belt away from the axle.
  17. Shark Rocket Powerhead AH401 Motor Replacement, Motor: 步骤 17 中的图像 1,1
    • Remove two 16mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  18. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 18 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 18 中的图像 2,2
    • Remove the belt-assembly unit by pulling the belt-assembly unit away from the motor.
  19. Shark Rocket Powerhead AH401 Motor Replacement: 步骤 19 中的图像 1,2 Shark Rocket Powerhead AH401 Motor Replacement: 步骤 19 中的图像 2,2
    • Rotate the motor unit over so that the wires are exposed.
    • Cut wires with cutting pliers to release the motor.
结论
4等其他人完成本指南。
Shobhit Dabral
于01/24/18注册
901 声望
创作了6篇指南
团队
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G3
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 34
总计 3,946
