跳转到主内容
Shark Rocket Powerhead AH401 Motherboard Replacement
你所需要的
  1. Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: 步骤 1 中的图像 1,3 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: 步骤 1 中的图像 2,3 Shark Rocket Powerhead AH401 Motherboard Replacement, Brushroll: 步骤 1 中的图像 3,3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 2 中的图像 1,2 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: 步骤 3 中的图像 1,3 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: 步骤 3 中的图像 2,3 Shark Rocket Powerhead AH401 Motherboard Replacement, Dust Cup: 步骤 3 中的图像 3,3
    • Push down on the dust can lever to release the dust can in order to get to the filter grill.
  4. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 4 中的图像 1,2 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the dust cup by lifting it off the dock.
  5. Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: 步骤 5 中的图像 1,2 Shark Rocket Powerhead AH401 Motherboard Replacement, Back Panel Screws: 步骤 5 中的图像 2,2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  6. Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Shark Rocket Powerhead AH401 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the three 10mm screws by rotating counter clockwise with a T15 Torx screwdriver.
    • Remove the airpath grille by gently lifting up and away from the motor compartment.
  7. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove two 14mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 8 中的图像 1,3 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 8 中的图像 2,3 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Lift and gently remove the hinge compartment covering the motherboard.
  9. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the two 10mm screws by rotating counter-clockwise with a T10 Torx screwdriver
  10. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 10 中的图像 1,2 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Lift the motherboard out of its compartment.
  11. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 11 中的图像 1,3 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 11 中的图像 2,3 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Locate and remove these connections by pulling the plugs out of the sockets.
  12. Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 12 中的图像 1,3 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 12 中的图像 2,3 Shark Rocket Powerhead AH401 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Flip the motherboard over to reveal the wires underneath.
    • Locate and cut all the wires connected to the motherboard using cutting pliers.
结论
Shobhit Dabral
于01/24/18注册
901 声望
创作了6篇指南
团队
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G3
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 506
