跳转到主内容
Shark Rocket Powerhead AH401 Brushroll Replacement
  1. Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: 步骤 1 中的图像 1,3 Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: 步骤 1 中的图像 2,3 Shark Rocket Powerhead AH401 Brushroll Replacement, Brushroll: 步骤 1 中的图像 3,3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Brushroll Replacement: 步骤 2 中的图像 1,2 Shark Rocket Powerhead AH401 Brushroll Replacement: 步骤 2 中的图像 2,2
    • Lift the brushroll out by pulling the tab labeled "pull".
结论
Toan Pham
于01/24/18注册
260 声望
创作了3篇指南
团队
Cal Poly, Team S19-G3, Livingston Winter 2018 Cal Poly, Team S19-G3, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G3
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 886
