简介
This guide will teach you how to remove and replace the rotary brush on the Shark Rocket HV301. There are a few reasons you may need to replace the rotary brush on your vacuum. For instance, the bristles may wear over time or the bearing caps on the ends of the brush may seize up, preventing the brush from spinning properly.
This is a simple repair that can be done by anyone and can improve the capabilities and lifespan of your vacuum. It can be done with common tools almost everyone should have easy access to. However, links are provided throughout in the case that you do not have one of the necessary tools. A link to the owner's manual can be found found here.
Flip the vacuum so the bottom base is visible.
Gently pry the bottom two wheels off with a plastic opening tool.
16等其他人完成本指南。
22条评论
This is a well written and very informative tutorial. Thank you for your time and effort. However, I am finding it difficult to locate a new rotary brush for my Shark Rocket model HV301. At best, I’ve been told that the rotary brushes available ‘May fit’ my vacuum. Hardly a resounding voice of confidence when ordering a replacement part. Does anyone know the part number or ordering information regarding the Shark Rocket model HV301 rotary brush? Thank you for your time.
I also need a new brush did you find out where to get one and could you pass it on to me thank you
Jeffro -
Hi, I'm also having a hard time trying to find the rotary brush roll, does anyone have any suggestions where I can find & purchase it?
Try Amazon.com there are several parts for shark vacuum, just make sure to have the model number in hand. I hope this help.
Thanks!
Andres B -
