跳转到主内容
Shark Professional Steam Pocket Mop Steam Nozzle Replacement
你所需要的
  1. Shark Professional Steam Pocket Mop Steam Nozzle Replacement, Steam Nozzle: 步骤 1 中的图像 1,1
    • Press the mop head release button to remove it from the steam mop body.
  2. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 步骤 2 中的图像 1,1
    • Remove the four 10mm screws holding the joint assembly to the mop head with your Phillips #2 screwdriver.
  3. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 步骤 3 中的图像 1,1
    • Remove the two plastic hinge covers by pulling the hinges out of the joint and sliding the covers off.
  4. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 步骤 4 中的图像 1,1
    • Stretch joint assembly forward to expose two 11mm Phillips #2 screws on either side of the steam tube.
    • Remove both screws.
  5. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 步骤 5 中的图像 1,1
    • Lift joint assembly out of hinge socket and pull upward with mild force to disconnect steam nozzle.
  6. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 步骤 6 中的图像 1,1
    • Use needle nose pliers to compress metal clamp .
  7. Shark Professional Steam Pocket Mop Steam Nozzle Replacement: 步骤 7 中的图像 1,1
    • Pull the nozzle out of the tube.
结论
另外一个人完成了本指南。
Michael Raymond
于02/12/18注册
154 声望
撰写一个指南
团队
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G1
4 名成员
创作了14篇指南
2条评论
This was fantastic. Only place I found on how to disassemble mop head. If i were you, I would go a little further and explain how to clean the nozzle. Use a paper clip or 20 gauge wire to push build up out. If that does not work use a small drill bit ( be careful to drill straight or you could damage the wall or jacket . This worked for me. Saved me $30. Had a problem locating this sight. Maybe some way to make it easier to locate would help. Thanks for your posting.
Mike Cunningham - 回复
Do you know if I can soak this part in clr? I can't seem to clean it well enough.
Kelsey Harper -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 78
总计 4,449
