跳转到主内容
Shark Professional Steam Pocket Mop Heating Element Replacement
你所需要的
  1. Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 步骤 1 中的图像 1,2 Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 步骤 1 中的图像 2,2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 2 中的图像 1,3 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 2 中的图像 2,3 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 2 中的图像 3,3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 3 中的图像 1,2 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 3 中的图像 2,2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 4 中的图像 1,3 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 4 中的图像 2,3 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 4 中的图像 3,3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 5 中的图像 1,3 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 5 中的图像 2,3 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 5 中的图像 3,3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 6 中的图像 1,1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop Heating Element Replacement, Shark Professional Steam Pocket Mop Open Mop Body: 步骤 7 中的图像 1,1
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  8. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 8 中的图像 1,1
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  9. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 9 中的图像 1,1
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  10. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 10 中的图像 1,1
    • Pop off the dark grey plastic trim cover.
  11. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 11 中的图像 1,1
    • Pop open the white plastic mop body by pulling apart from the front and back side.
  12. Shark Professional Steam Pocket Mop Heating Element Replacement, Heating Element: 步骤 12 中的图像 1,1
    • Remove the four 12.0 mm Phillips head #2 screws on the sides of the heating element.
  13. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 13 中的图像 1,2 Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Pull out the heating element and use precision tweezers or pliers to pinch and loosen the two clamps.
    • Remove both tubes from the heating element.
  14. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 14 中的图像 1,1
    • Grip each wire at its base and pull to disconnect them from the heating element.
  15. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 15 中的图像 1,1
    • Remove two 12.0 mm Phillips head #2 screws from the heating element.
  16. Shark Professional Steam Pocket Mop Heating Element Replacement: 步骤 16 中的图像 1,1
    • Pull apart wire connectors to fully detach the heating element.
结论
3等其他人完成本指南。
Brett Wilson
于02/12/18注册
992 声望
创作了6篇指南
团队
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G1
4 名成员
创作了14篇指南
8指南评论
Is the heating element available somewhere? I cannot find it anywhere.
Mark Cashion - 回复
Where can the heating element be purchased in order to replace? Can’t find anywhere.
Amanda Krusenstjerna - 回复
i have a shark s3973d. and i need a heating elementand the two hosese connected
to the heating element. if no heating element. would like to order the hoses.
RICHARD MARTINEZ - 回复
Once element is detached where do I get a new one
Sandra R Pannell - 回复
I just bought this shark steam vac less than 6months ago
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 94
总计 6,867
