简介
The electric valve controls the flow of water from the tank to the heating element. If the tank is full and the mop isn't producing any steam, the electric valve might be the problem. Before doing any disassembly on your Shark Professional Steam Pocket Mop, unplug the mop and empty the water tank for your safety.
你所需要的
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
Remove the four 12.0 mm Phillips head #2 screws on top of the electric valve.
2等其他人完成本指南。
