跳转到主内容
Shark Professional Steam Pocket Mop Control Panel Replacement
你所需要的
  1. Shark Professional Steam Pocket Mop Control Panel Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 步骤 1 中的图像 1,2 Shark Professional Steam Pocket Mop Control Panel Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 步骤 1 中的图像 2,2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 2 中的图像 1,3 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 2 中的图像 2,3 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 2 中的图像 3,3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 3 中的图像 1,2 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 3 中的图像 2,2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 4 中的图像 1,3 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 4 中的图像 2,3 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 4 中的图像 3,3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 5 中的图像 1,3 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 5 中的图像 2,3 Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 5 中的图像 3,3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Control Panel Replacement: 步骤 6 中的图像 1,1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop Control Panel Replacement, Control Panel: 步骤 7 中的图像 1,2 Shark Professional Steam Pocket Mop Control Panel Replacement, Control Panel: 步骤 7 中的图像 2,2
    • Remove the two 12.0 mm Phillips head #2 screws. Disconnect the control board.
    • Disconnect the control board
结论
Brett Wilson
于02/12/18注册
992 声望
创作了6篇指南
团队
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 730
