跳转到主内容
Shark Professional Steam Pocket Mop Open Mop Body Replacement
你所需要的
  1. Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 步骤 1 中的图像 1,2 Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Front Panel Disassembly: 步骤 1 中的图像 2,2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 2 中的图像 1,3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 2 中的图像 2,3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 2 中的图像 3,3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 3 中的图像 1,2 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 3 中的图像 2,2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 4 中的图像 1,3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 4 中的图像 2,3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 4 中的图像 3,3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 5 中的图像 1,3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 5 中的图像 2,3 Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 5 中的图像 3,3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 6 中的图像 1,1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
  7. Shark Professional Steam Pocket Mop  Open Mop Body Replacement, Shark Professional Steam Pocket Mop Open Mop Body: 步骤 7 中的图像 1,1
    • Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
  8. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 8 中的图像 1,1
    • Remove the four 16.0 mm T10 Torx screws located on the back of the mop.
  9. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 9 中的图像 1,1
    • Remove the two 12.0 mm Phillips head #2 screws that hold the power cord to the device.
  10. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 10 中的图像 1,1
    • Pop off the dark grey plastic trim cover.
  11. Shark Professional Steam Pocket Mop  Open Mop Body Replacement: 步骤 11 中的图像 1,1
    • Pop open the white plastic mop body by pulling apart from the front and back side.
结论
2等其他人完成本指南。
Brett Wilson
于02/12/18注册
992 声望
创作了6篇指南
团队
USF Tampa, Team S15-G1, Boczar Spring 2018 USF Tampa, Team S15-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G1
4 名成员
创作了14篇指南
一条评论
good afternoon, i need the water pump for that shark steamer. my model is S3601A.
Thank you.
Eduardo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 45
总计 5,458
