跳转到主内容
Shark Navigator Roller Brush Replacement
你所需要的
  1. Shark Navigator Roller Brush Replacement, Roller Brush Compartment: 步骤 1 中的图像 1,1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Roller Brush Replacement: 步骤 2 中的图像 1,2 Shark Navigator Roller Brush Replacement: 步骤 2 中的图像 2,2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Roller Brush Replacement: 步骤 3 中的图像 1,1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Roller Brush Replacement, Roller Brush: 步骤 4 中的图像 1,1
    • Lift the roller brush out of its holders.
结论
42等其他人完成本指南。
Jeremiah Shyne
于03/27/15注册
1,403 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G4
4 名成员
创作了16篇指南
35条评论
Instructions where so easy to follow & right on the money. It took me 11 min from start to finish. PERFECT!!!
Cole bohn - 回复
Very helpful and easy. Thank you.
Kristi cox - 回复
Thank you. The owner's manual doesn't take into account needing to disassemble to clean the brush, for those of us with super long hair. Your instructions pointed out the screws under the wheels that we were missing.
birdofpyre - 回复
Ive uscrewed everything and this white piece seems to be stuck toward the rear. I even took the back whells off.
falynkinsey - 回复
Thank you so much. After having had to send in vac due to recall could not bare to part with it again to fix the belt. Your instructions for very clear and easy to follow. Thank you June
interhome1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 34
过去 30 天: 196
总计 98,913
