跳转到主内容
Shark Navigator Motor Replacement
你所需要的
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: 步骤 1 中的图像 1,1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: 步骤 2 中的图像 1,2 Shark Navigator Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: 步骤 3 中的图像 1,1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: 步骤 4 中的图像 1,1
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
结论
Molina Oung
于03/27/15注册
289 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G4
4 名成员
创作了16篇指南
6指南评论
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - 回复
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - 回复
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Have no suction but the roller still spins can it still be the Motor ?
Thompson Mick - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 120
总计 17,595
