跳转到主内容
Shark Navigator Motherboard Replacement
你所需要的
  1. Shark Navigator Motherboard Replacement, Roller Brush Compartment: 步骤 1 中的图像 1,1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motherboard Replacement: 步骤 2 中的图像 1,2 Shark Navigator Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • There is one screw at the edge of the circuit board. Unscrew the circuit board before attempting to take it out.
  5. Shark Navigator Motherboard Replacement: 步骤 5 中的图像 1,1
    • Take out the circuit board and replace with a new one. It may be better to allow a professional to re-wire the circuit board to the vacuum.
结论
3等其他人完成本指南。
Mara
于03/27/15注册
469 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-4, Kish Spring 2015 UMass Dartmouth, Team 5-4, Kish Spring 2015 的会员
UMASSD-KISH-S15S5G4
4 名成员
创作了16篇指南
8条评论
Hi ..well done with the instructions.However I do have a Shark rotator vacuum NV501 .Unfortunately the motor on the brush is not working ,so I assume the motor is burnt.My request where could I find a replacement of the motor.I have searched a lot sites online but could not find a place to rebuild nor stock the same motor.Any help would be appreciated.Thank you.....To forward any information please do so on my email jacob.brown at hotmail.com thank you....
jacob - 回复
I couldn't figure out how to remove the bottom plate, your guide helped by informing me the last two screws are located under the little wheels. Thank you!
dylananon - 回复
When I had mine apart, two black rectangle magnet fell out, I can't figure out where the came from.
mardit - 回复
I had the same problem with the magnets - where do they go>
bjolivares1055 -
Also having problem locating both mother board and brush roller motor. Where can i purchase them?
Liz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 7,696
