跳转到主内容
Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: 步骤 1 中的图像 1,3 Shark Navigator Lightweight Upright Hose Replacement, Hose: 步骤 1 中的图像 2,3 Shark Navigator Lightweight Upright Hose Replacement, Hose: 步骤 1 中的图像 3,3
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: 步骤 2 中的图像 1,2 Shark Navigator Lightweight Upright Hose Replacement: 步骤 2 中的图像 2,2
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: 步骤 3 中的图像 1,3 Shark Navigator Lightweight Upright Hose Replacement: 步骤 3 中的图像 2,3 Shark Navigator Lightweight Upright Hose Replacement: 步骤 3 中的图像 3,3
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
结论
另外一个人完成了本指南。
Kahye Yu
于10/02/17注册
446 声望
创作了2篇指南
团队
Cal Poly, Team S4-G6, Livingston Fall 2017 Cal Poly, Team S4-G6, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G6
3 名成员
创作了12篇指南
3条评论
Where can I find a replacement hose?
Vance Payne - 回复
How to replace the bottom pick up hose.
rgg20319 - 回复
How to fix the bottom hose?
rgg20319 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 58
总计 3,474
