跳转到主内容
Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement
你所需要的
  1. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: 步骤 1 中的图像 1,2 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement, Self Cleaning Brush Roll: 步骤 1 中的图像 2,2
    • Make sure to turn off the vacuum and unplug it from the outlet.
  2. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 步骤 2 中的图像 1,3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 步骤 2 中的图像 2,3 Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 步骤 2 中的图像 3,3
    • Push down on the bottom of the vacuum so it can dangle.
    • Using a flathead screwdriver to turn the lock counterclockwise, then open the cover to access the brush roll.
  3. Shark Navigator Lift-Away Upright UV725BXBRN Brush Roll Replacement: 步骤 3 中的图像 1,1
    • Clear out any debris and close up the bottom using the previous steps.
    • Unfortunately, the new technology implemented in the self-cleaning brush roll prevents it from being detachable. You have a guaranteed 5-year warranty from Shark. Contact them using this link.
结论
To reassemble your device, follow these instructions in reverse order. Also if your self-cleaning brush roll doesn’t work at all. You have a 5-year warranty with the manufacture and will be replaced. Go to this link and they will help you immediately. https://support.sharkclean.com/hc/en-us/...
2等其他人完成本指南。
附加文件
团队
CSU Los Angeles, Team 11-5, Grodsky Fall 2021 CSU Los Angeles, Team 11-5, Grodsky Fall 2021 的会员
CSULA-GRODSKY-F21S11G5
1 名成员
创作了2篇指南
一条评论
The brush roller and placement of it is filthy with dog hair and dirt needs to be scraped out. There must be a way to remove it to clean without having to send it to the manufacturer
Nana - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 143
总计 5,394
