跳转到主内容
Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement
你所需要的
  1. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush Belt: 步骤 1 中的图像 1,2 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush Belt: 步骤 1 中的图像 2,2
    • Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
  2. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 2 中的图像 1,3 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 2 中的图像 2,3 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 2 中的图像 3,3
    • Insert the metal spudger between the inside side of the wheel and the plastic body.
    • Push the metal spudger away from you to pop the wheels out.
    • Repeat the step to remove the other wheel on the other side.
  3. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 3 中的图像 1,1
    • Remove the six 15mm screws using the PH1 screwdriver.
  4. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 4 中的图像 1,2 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 4 中的图像 2,2
    • Move the blue fulcrum connecting the bottom and the main body of the vacuum cleaner back and forth to loosen up crevice between the two halves of the roller brush enclosure.
  5. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 5 中的图像 1,3 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 5 中的图像 2,3 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 5 中的图像 3,3
    • Insert the plastic opening tool into the crevice between the blue and the dark grey plastic frames enclosing the roller brush.
    • Apply an outward force throughout and all around the gap in order to separate the two plastic frames.
  6. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 6 中的图像 1,2 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 6 中的图像 2,2
    • Lift the grey frame off the bottom of the vacuum cleaner with your hands and place it on a flat surface.
  7. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 7 中的图像 1,3 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 7 中的图像 2,3 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 7 中的图像 3,3
    • Lift the roller brush slightly upwards using your hand.
    • Take one side of the black roller brush belt off by pulling it over the end of the roller brush with your other hand.
  8. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement: 步骤 8 中的图像 1,1
    • Remove the roller brush belt with your hands by sliding it of the end of the motor.
  9. Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush: 步骤 9 中的图像 1,2 Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement, Roller Brush: 步骤 9 中的图像 2,2
    • Remove the roller brush from the plastic frame using your hands by lifting it away.
结论
14等其他人完成本指南。
团队
Cal Poly, Team S15-G2, Livingston Fall 2017 Cal Poly, Team S15-G2, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G2
3 名成员
创作了14篇指南
3条评论
What is the part number for the roller brush?
Sean E. Belew - 回复
what is the part number for the motor and motherboard
benjpatt - 回复
Worst screw types. You suck
Ace - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 94
过去 30 天: 491
总计 43,734
