跳转到主内容
Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement, Foam and Felt Filters: 步骤 1 中的图像 1,1
    • Locate the latches on the side of the dust cup, the clear plastic chamber in the center of the vacuum.
  2. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 2 中的图像 1,3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 2 中的图像 2,3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 2 中的图像 3,3
    • Pull the bottom of the latch with your hand in an upward direction.
    • Lift the top of the latch up and away from the dust cup using your hand.
    • Repeat the above steps with the latch on the other side of the dust cup.
  3. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 3 中的图像 1,2 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 3 中的图像 2,2
    • Lift the dust cup up and away by its handle on the top with your hands.
  4. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 4 中的图像 1,3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 4 中的图像 2,3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 4 中的图像 3,3
    • Lift the foam filter up, out, and away with your hands.
  5. Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 5 中的图像 1,3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 5 中的图像 2,3 Shark Navigator Lift-Away Deluxe NV360 Foam and Felt Filters Replacement: 步骤 5 中的图像 3,3
    • Lift the felt filter up, out, and away with your hands by the tab on the top.
结论
2等其他人完成本指南。
Pramika Kumar
于09/30/17注册
258 声望
撰写一个指南
团队
Cal Poly, Team S15-G2, Livingston Fall 2017 Cal Poly, Team S15-G2, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G2
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 59
总计 5,089
