简介
When the roller belt has snapped or your vacuum's roller brush is not spinning, you should look into replacing your roller belt.
你所需要的
Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum.
Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum.
Same thing happened to still have spring and assembled leaving it out and motor will not start
Ok, finally fixed. Putting the little spring back is key. Suggestion: the lay the white top upside down on table, drop spring into tube where it goes then reassemble in upside down position so spring doesn’t fall putting vacuum back together,
Remove the belt by sliding it off the end of the motor.
are you &&^&^$^ kidding?????????????????
i'm 85 will never buy a shark product again
Solution, go buy a new vac!🤓
4等其他人完成本指南。
20条评论
Where can I purchase the belt. It is a “Pioneer Rubber Belt 148 2m”.
Please contact me.
Thank you.
itsagas03@hotmail.com
Try amazon…replacement belt for shark navigator freestyle cordless vacuum
I got the belt from http://shop.polybelt.com/ It is item B148-2M-04BNG . You have to buy 3 to get to $9.99 and then they tack on another $10 for shipping, but this was the only place I could find them. Replaced it and it seems to be working ok.
The brush stops tolling after a few seconds. How do I trouble shoot this?
Same happens to me. I took it all apart; there was not much hair in the mechanisms at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next.
Same problem for me. Not a happy camper after spending money and time to have the same problem.
Hi Pete, I found by removing the roller brush, you will be able to remove accumulated hair strands around the brush and related bearings. Having problems finding the 2mm x 148 belt. however it looks like “rmagnus” hit pay dirt through shop.polybelt.com. I’ll give that a shot.
Good luck.
Found a source for the belt https://shop.polybelt.com/searchquick-su...
I wish you could mention the spring…
The spring goes in the long screw hole in the top cover.
Google search of model # reveals several sources for belts. Most from China requiring 4 week wait.
I followed the instructions (which are great) and got it apart and replaced the belt. Put it back together and it will not turn on. Been charging for awhile. Is there something I did wrong when I put it back together?
The brush stops rolling after a few seconds. I took it all apart; there was not much hair in the mechanism at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next? Any advice, please?
My 14.4 version of the freestyle will not run if the upper assembly is attached. When turned on the roller motor runs for 2 seconds and then shuts off. Is the Suction motor in the handle dead? There are no clogs or tangles. Again…when the handle is detached the brush motor runs.but shuts of in 2 seconds. The suction motor does not start.
I wish you had mentioned the spring, I didn’t see where it came from.
Hello:
I just replaced the belt today in this vacuum, this tutorial was awesome & helpful. When putting it all back together a spring fell out and I have no idea where it might go, so I thought I’d inquire and see if you can provide any insight. It’s 1 3/4 in. long and resembles a spring you would find in a pen, but it’s smaller in diameter. Any help would be much appreciated.
Follow up to previous post…deductive reasoning told me that spring likely went into the hole connected to the on/off button. It fit in the hole so that’s were I left it! I put it all back together…and it low and behold started!! So I hope my guess was correct…if it wasn’t, oh well…it worked!! Haha!!
The belt may not be broken but warn down so it slips and doesn’t turn the brush. You can buy them on Amazon in packs of 2
