跳转到主内容
Shark Navigator Freestyle SV1106 Roller Belt Replacement
你所需要的
  1. Shark Navigator Freestyle SV1106 Roller Belt Replacement, Battery Pack: 步骤 1 中的图像 1,1
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 2 中的图像 1,2 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 2 中的图像 2,2
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 3 中的图像 1,1
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 4 中的图像 1,2 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 4 中的图像 2,2
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 5 中的图像 1,2 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
  6. Shark Navigator Freestyle SV1106 Roller Belt Replacement, Roller Belt: 步骤 6 中的图像 1,3 Shark Navigator Freestyle SV1106 Roller Belt Replacement, Roller Belt: 步骤 6 中的图像 2,3 Shark Navigator Freestyle SV1106 Roller Belt Replacement, Roller Belt: 步骤 6 中的图像 3,3
    • Remove the eight 25.4 mm Phillips #1 screws holding the bottom panel to the vacuum.
    • Use the metal spudger to remove the plastic plug to reveal a 12.4 mm Phillips #1 screw and remove it.
  7. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 7 中的图像 1,1
    • Remove the final 25.4 mm Phillips #1 screw inside the battery compartment.
  8. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 8 中的图像 1,3 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 8 中的图像 2,3 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 8 中的图像 3,3
    • Remove the bottom panel from the vacuum by pressing to release the latches at the front and pulling the bottom panel away from the vacuum.
  9. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 9 中的图像 1,3 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 9 中的图像 2,3 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 9 中的图像 3,3
    • Remove the 12.2 mm Phillips #1 screws holding the motor in place and remove the motor by pulling directly upwards.
  10. Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 10 中的图像 1,2 Shark Navigator Freestyle SV1106 Roller Belt Replacement: 步骤 10 中的图像 2,2
    • Remove the belt by sliding it off the end of the motor.
结论
4等其他人完成本指南。
Zachary Liu
于01/24/18注册
604 声望
创作了5篇指南
团队
Cal Poly, Team S1-G5, Livingston Winter 2018 Cal Poly, Team S1-G5, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S1G5
3 名成员
创作了10篇指南
20条评论
Where can I purchase the belt. It is a “Pioneer Rubber Belt 148 2m”.
Please contact me.
Thank you.
itsagas03@hotmail.com
itsagas03 - 回复
Try amazon…replacement belt for shark navigator freestyle cordless vacuum
Cathy Martin -
I got the belt from http://shop.polybelt.com/ It is item B148-2M-04BNG . You have to buy 3 to get to $9.99 and then they tack on another $10 for shipping, but this was the only place I could find them. Replaced it and it seems to be working ok.
rmagnus - 回复
The brush stops tolling after a few seconds. How do I trouble shoot this?
Peter Fogler - 回复
Same happens to me. I took it all apart; there was not much hair in the mechanisms at all, and the belt is not broken so I don't see the need to replace it. I am at a loss as to what I should do next.
Esther Odneal -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 84
总计 6,206
