简介
The HEPA filter is an air filter that traps harmful particles, such as pollen or dust. If it has been over a year or there is a bad odor when you use your vacuum, it might be time to replace the filter. Follow these steps to remove your filter either to clean or replace it.
Put two or three fingers under the tab located at the bottom of the HEPA Filter.
Push upwards on the tab at a slight angle to take off the cover.
3等其他人完成本指南。
