跳转到主内容
Shark Matrix RV2310 Wheel Assembly Replacement
你所需要的
  1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the two 11 mm Phillips screws holding the battery plate in place.
    • Remove the battery plate.
  2. Shark Matrix RV2310 Wheel Assembly Replacement: 步骤 2 中的图像 1,3 Shark Matrix RV2310 Wheel Assembly Replacement: 步骤 2 中的图像 2,3 Shark Matrix RV2310 Wheel Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove the battery from the compartment.
    • Disconnect the electrical cable connection from the battery to the robot.
  3. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: 步骤 3 中的图像 1,2 Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: 步骤 3 中的图像 2,2
    • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
    • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
  4. Shark Matrix RV2310 Wheel Assembly Replacement: 步骤 4 中的图像 1,1
    • Lift the wheel assembly out of the vacuum.
    • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
  5. Shark Matrix RV2310 Wheel Assembly Replacement: 步骤 5 中的图像 1,1
    • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
结论
Joshua Correia
于03/22/24注册
631 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-4, Botvin Spring 2024 UMass Dartmouth, Team 6-4, Botvin Spring 2024 的会员
UMASSD-BOTVIN-S24S6G4
2 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 60
总计 578
