跳转到主内容
Shark IQ AV993 Bumper Replacement
你所需要的
  1. Shark IQ AV993 Bumper Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Bumper Replacement: 步骤 2 中的图像 1,1
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
  3. Shark IQ AV993 Bumper Replacement, Bumper: 步骤 3 中的图像 1,2 Shark IQ AV993 Bumper Replacement, Bumper: 步骤 3 中的图像 2,2
    • Remove the five 10 mm screws from the bottom of the device using a T15 Torx screwdriver.
  4. Shark IQ AV993 Bumper Replacement: 步骤 4 中的图像 1,1
    • Pry both ends of the black piece to snap it out of place.
  5. Shark IQ AV993 Bumper Replacement: 步骤 5 中的图像 1,1
    • Use both hands to lift the device.
    • The front bumper that is seated on the device will fall off.
    • This is completely normal, as the screws and the bottom holder are the only things holding the bumper in place.
结论
Kyle Rhines
于10/26/22注册
558 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-3, Botvin Fall 2022 UMass Dartmouth, Team 3-3, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 33
总计 789
