跳转到主内容
Shark IQ AV993 Battery Replacement
你所需要的
  1. Shark IQ AV993 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 14 mm screws on the battery panel using a Phillips #1 screwdriver.
  2. Shark IQ AV993 Battery Replacement: 步骤 2 中的图像 1,1
    • Gently pull the white tabs on the battery straight upward.
    • There is a clip inserted into a plastic housing via wiring. Disconnect the battery by pressing in the clip.
    • Don't pull up on the battery too hard as a wire connects to the robot. Don't want to damage the wire here.
    • Remove the battery from the device.
结论
2等其他人完成本指南。
Kyle Rhines
于10/26/22注册
558 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-3, Botvin Fall 2022 UMass Dartmouth, Team 3-3, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 304
