跳转到主内容
Shark IONFlex 2X Soft Brush Roll Replacement
  1. Shark IONFlex 2X Soft Brush Roll Replacement, Soft Brush Roll: 步骤 1 中的图像 1,1
    • Press and slide the access brush roll buttons towards the "Access Brush Roll" printing on casing.
  2. Shark IONFlex 2X Soft Brush Roll Replacement: 步骤 2 中的图像 1,1
    • Lift plastic casing upward and off of the top of the floor unit. Place off to the side.
  3. Shark IONFlex 2X Soft Brush Roll Replacement: 步骤 3 中的图像 1,1
    • Pull the red Pull tab that is located on the right side of the soft brush roll away from the front of the vacuum and place the soft brush roll to the side.
    Hello, i misplaced the black end part where you attach the soft brush to the vacuum. Is on the left side. Can you tell me if they sell the part?
    Maria Gonzalez - 回复
结论
2等其他人完成本指南。
1指南评论
I’m trying to fix the plastic gear that the roller fits onto. It’s broken and I think it needs to be disassembled more and need replacement parts. Model # IF200W. Any advice??
Anthony - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 2,846
