跳转到主内容
Shark ION Robot S87 Drive Wheel Replacement
你所需要的
  1. Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: 步骤 1 中的图像 1,2 Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: 步骤 1 中的图像 2,2
    • Make sure device is turned off before attempting this replacement.
    • Remove three 13mm screws using a T15 Torx screwdriver.
    • Remove one 15mm screw using a Phillips #1 screwdriver.
    • Remove one final 15mm Phillips #1 screw.
  2. Shark ION Robot S87 Drive Wheel Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the wheel assembly out of the housing, making sure not to damage its connecting wire.
  3. Shark ION Robot S87 Drive Wheel Replacement: 步骤 3 中的图像 1,1
    • Disconnect the wire carefully from the wheel assembly by pinching and pulling away from it.
结论
另外一个人完成了本指南。
Trevor Davies
于01/14/20注册
297 声望
创作了2篇指南
团队
一条评论
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
DovieAndiSeTova - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 1,727
