跳转到主内容
Shark ION Robot S87 Bumper Replacement
你所需要的
  1. Shark ION Robot S87 Bumper Replacement, Bumper: 步骤 1 中的图像 1,1
    • Flip the Shark ION Robot S87 on its underside so that the bumper and its screws are facing upwards.
    • Use a Hex 2mm screwdriver to remove the five 8mm screws from the bumper.
  2. Shark ION Robot S87 Bumper Replacement: 步骤 2 中的图像 1,3 Shark ION Robot S87 Bumper Replacement: 步骤 2 中的图像 2,3 Shark ION Robot S87 Bumper Replacement: 步骤 2 中的图像 3,3
    • Once all screws have been removed lift the thin side of the bumper upwards to remove it from the robot.
    • Lift the robot up so that the larger part of the bumper stays on the floor and is removed.
    • Once both pieces of the bumper have been removed, you can place the robot back down.
  3. Shark ION Robot S87 Bumper Replacement: 步骤 3 中的图像 1,1
    • Check all sensors and remove any that may have debris in front of it.
    • You may also swap out the bumper for another depending on whether or not it is broken.
结论
2等其他人完成本指南。
Adeel Ahmad
于01/14/20注册
256 声望
创作了2篇指南
团队
一条评论
Where can I buy a new bumper?
Lacy - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 83
总计 12,792
