跳转到主内容
Shark ION Robot R75 Side Brush Replacement
你所需要的
  1. Shark ION Robot R75 Side Brush Replacement, Side Brush: 步骤 1 中的图像 1,3 Shark ION Robot R75 Side Brush Replacement, Side Brush: 步骤 1 中的图像 2,3 Shark ION Robot R75 Side Brush Replacement, Side Brush: 步骤 1 中的图像 3,3
    • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
    • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
结论
2条评论
I have removed/lost my screw that went inside the side brush. Do you have screw size recommendation to replace it? Shark doesn't sell them and says the brush may fall off if I don't have my screw. Is it guaranteed that Phillips #1 Screwdriver would be able to remove screws? I have tried all types of screwdrivers and haven't found one to remove the other screw to take it to the store to find the right size to replace what I am missing.
Kell S - 回复
Our Shark AV1002AE needs a Torx T-9 to remove the screw. However we have not found a replacement screw or insert
Kathy - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 153
总计 6,312
