跳转到主内容
Shark ION Robot R75 Main Brush Replacement
  1. Shark ION Robot R75 Main Brush Replacement, Main Brush: 步骤 1 中的图像 1,1
    • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
  2. Shark ION Robot R75 Main Brush Replacement: 步骤 2 中的图像 1,1
    • Pull the main brush slightly to the right to remove it from the compartment.
  3. Shark ION Robot R75 Main Brush Replacement: 步骤 3 中的图像 1,2 Shark ION Robot R75 Main Brush Replacement: 步骤 3 中的图像 2,2
    • Remove the rubber end cap indicated by the red circle.
    • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
    • Inspect this component at least every six months. This time may be less if you have animals.
结论
一条评论
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 61
总计 2,721
