跳转到主内容
Shark ION Robot R75 Caster Wheel Replacement
你所需要的
  1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: 步骤 1 中的图像 1,1
    • Orient the device with the bottom facing up.
  2. Shark ION Robot R75 Caster Wheel Replacement: 步骤 2 中的图像 1,3 Shark ION Robot R75 Caster Wheel Replacement: 步骤 2 中的图像 2,3 Shark ION Robot R75 Caster Wheel Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
    • Remove the wheel.
  3. Shark ION Robot R75 Caster Wheel Replacement: 步骤 3 中的图像 1,3 Shark ION Robot R75 Caster Wheel Replacement: 步骤 3 中的图像 2,3 Shark ION Robot R75 Caster Wheel Replacement: 步骤 3 中的图像 3,3
    • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
    • Pull the caster assembly up from its slot in the device.
结论
1指南评论
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 44
总计 5,705
