跳转到主内容
Shark ION Robot 750 Outer Shell Replacement
你所需要的
  1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 2,3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Make sure the device is completely powered off before working.
    • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
    • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
    • Remove the nine 9.1mm Torx T6 bolts from outer shell.
  2. Shark ION Robot 750 Outer Shell Replacement: 步骤 2 中的图像 1,2 Shark ION Robot 750 Outer Shell Replacement: 步骤 2 中的图像 2,2
    • Slightly pull front bumper to expose internal wiring.
    • Unplug the device’s front bumper wiring and completely remove front bumper.
  3. Shark ION Robot 750 Outer Shell Replacement: 步骤 3 中的图像 1,2 Shark ION Robot 750 Outer Shell Replacement: 步骤 3 中的图像 2,2
    • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
    • Gently depress the two tabs on the frame, then lift the frame to remove it.
  4. Shark ION Robot 750 Outer Shell Replacement: 步骤 4 中的图像 1,2 Shark ION Robot 750 Outer Shell Replacement: 步骤 4 中的图像 2,2
    • Pick up the brush and remove it from the vacuum.
    • Push the brush to your right and lift it.
  5. Shark ION Robot 750 Outer Shell Replacement: 步骤 5 中的图像 1,3 Shark ION Robot 750 Outer Shell Replacement: 步骤 5 中的图像 2,3 Shark ION Robot 750 Outer Shell Replacement: 步骤 5 中的图像 3,3
    • Press and hold the dust bin removal button to slide out the dust bin.
  6. Shark ION Robot 750 Outer Shell Replacement: 步骤 6 中的图像 1,1
    • Lift the outer shell to expose the Shark’s interior.
结论
Youness Elfath
于09/13/23注册
183 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 243
