跳转到主内容
Shark ION Robot 750 Charging Dock Motherboard Replacement
你所需要的
  1. Shark ION Robot 750 Charging Dock Motherboard Replacement, Charging Dock: 步骤 1 中的图像 1,1
    • Remove the three Torx T6 screws on the underside of the charging dock.
    • Lift off the lower case.
  2. Shark ION Robot 750 Charging Dock Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the four screws inside.
  3. Shark ION Robot 750 Charging Dock Motherboard Replacement: 步骤 3 中的图像 1,2 Shark ION Robot 750 Charging Dock Motherboard Replacement: 步骤 3 中的图像 2,2
    • Gently push in the tabs to remove the sensor housing.
  4. Shark ION Robot 750 Charging Dock Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unplug the two wires going into the motherboard, then gently lift the motherboard up and out of its slot.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 74
