跳转到主内容
Shark ION Robot 750 Button Panel Replacement
你所需要的
  1. Shark ION Robot 750 Button Panel Replacement, Button Panel: 步骤 1 中的图像 1,2 Shark ION Robot 750 Button Panel Replacement, Button Panel: 步骤 1 中的图像 2,2
    • Before you begin, make sure the vacuum is off.
    • Use a spudger to remove the top case of the vacuum.
    • Flip over the top case.
    • Use tweezers or your hands to remove the center button panel from the socket.
  2. Shark ION Robot 750 Button Panel Replacement: 步骤 2 中的图像 1,2 Shark ION Robot 750 Button Panel Replacement: 步骤 2 中的图像 2,2
    • Use your hands or tweezers to remove the other button panel from its socket.
    • Use a spudger to pop the panel off of the connector if you need help.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ashley Nguyen
于02/08/24注册
85 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 128
