跳转到主内容
Shark ION Robot 750 Battery Replacement
你所需要的
  1. Shark ION Robot 750 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: 步骤 2 中的图像 1,2 Shark ION Robot 750 Battery Replacement: 步骤 2 中的图像 2,2
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: 步骤 3 中的图像 1,2 Shark ION Robot 750 Battery Replacement: 步骤 3 中的图像 2,2
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 14
总计 110
