跳转到主内容
Shark Flex DuoClean Suction Motor Replacement
你所需要的
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: 步骤 1 中的图像 1,2 Shark Flex DuoClean Suction Motor Replacement, Dust Cup: 步骤 1 中的图像 2,2
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: 步骤 2 中的图像 1,1
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: 步骤 3 中的图像 1,1
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: 步骤 7 中的图像 1,1
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: 步骤 8 中的图像 1,1
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 的会员
CPSU-WHITE-F18S17G5
4 名成员
创作了14篇指南
1指南评论
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 3,920
