跳转到主内容
Shark Flex DuoClean Motherboard Replacement
你所需要的
  1. Shark Flex DuoClean Motherboard Replacement, Garage Door: 步骤 1 中的图像 1,2 Shark Flex DuoClean Motherboard Replacement, Garage Door: 步骤 1 中的图像 2,2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motherboard Replacement, Side Component: 步骤 2 中的图像 1,2 Shark Flex DuoClean Motherboard Replacement, Side Component: 步骤 2 中的图像 2,2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motherboard Replacement: 步骤 3 中的图像 1,2 Shark Flex DuoClean Motherboard Replacement: 步骤 3 中的图像 2,2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motherboard Replacement, Top Component: 步骤 6 中的图像 1,1
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motherboard Replacement: 步骤 7 中的图像 1,2 Shark Flex DuoClean Motherboard Replacement: 步骤 7 中的图像 2,2
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove one 15mm T10 screw from the inside left of the base of the vacuum to access the motherboard.
  9. Shark Flex DuoClean Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using the nylon spudger, place the curved side under the motherboard.
    • Gently pry the motherboard out of the base of the vacuum.
    • Do not use your fingers to take out the motherboard, as the bottom can be sharp.
    • The motherboard will still be connected to the base with wires.
  10. Shark Flex DuoClean Motherboard Replacement: 步骤 10 中的图像 1,1
    • Desolder the motherboard wires using wire cutters.
结论
团队
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 的会员
CPSU-WHITE-F18S17G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 1,391
