跳转到主内容
Shark Flex DuoClean Drive Belt Replacement
你所需要的
  1. Shark Flex DuoClean Drive Belt Replacement, Garage Door: 步骤 1 中的图像 1,2 Shark Flex DuoClean Drive Belt Replacement, Garage Door: 步骤 1 中的图像 2,2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Drive Belt Replacement, Side Component: 步骤 2 中的图像 1,2 Shark Flex DuoClean Drive Belt Replacement, Side Component: 步骤 2 中的图像 2,2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Drive Belt Replacement: 步骤 3 中的图像 1,2 Shark Flex DuoClean Drive Belt Replacement: 步骤 3 中的图像 2,2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Drive Belt Replacement: 步骤 4 中的图像 1,1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Drive Belt Replacement: 步骤 5 中的图像 1,1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Drive Belt Replacement, Drive Belt: 步骤 6 中的图像 1,2 Shark Flex DuoClean Drive Belt Replacement, Drive Belt: 步骤 6 中的图像 2,2
    • Remove old the belt from the two gears by prying it off using the metal spudger.
    • The new belt will be very tight and difficult to put back on. In order to reinstall, start with the belt on one gear, then slowly rotate the other gear, pushing on the belt and allowing it to catch the teeth.
  7. Shark Flex DuoClean Drive Belt Replacement: 步骤 7 中的图像 1,1
    • Repeat on the other side of the vacuum.
结论
9等其他人完成本指南。
团队
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 的会员
CPSU-WHITE-F18S17G5
4 名成员
创作了14篇指南
10条评论
Thanks… Would have taken me forever to figure out how to get to the belts…!!!
Mike Babb - 回复
Wonderful directions and a great help, thanks. However one important factor was left out, the part number for the belts.
Dave Orr - 回复
Where to get the carpet brush belt? What would the belt size be?
Silver Dominator - 回复
Add me to the rest. I also want a belt. Does anybody ever respond to these questions?
I’m hopeful we can find a source
ShellyB
shellyb -
the belt, roller brush, entire floor unit, etc are on amazon
john smith -
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 73
过去 30 天: 366
总计 53,693
