跳转到主内容
Shark Flex DuoClean Brush Roll Replacement
  1. Shark Flex DuoClean Brush Roll Replacement, Garage Door: 步骤 1 中的图像 1,2 Shark Flex DuoClean Brush Roll Replacement, Garage Door: 步骤 1 中的图像 2,2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Brush Roll Replacement, Soft Roller: 步骤 2 中的图像 1,2 Shark Flex DuoClean Brush Roll Replacement, Soft Roller: 步骤 2 中的图像 2,2
    • Use the tab on the right side to lift out the soft roller.
结论
2等其他人完成本指南。
caoimhe
于10/08/18注册
979 声望
创作了4篇指南
团队
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 的会员
CPSU-WHITE-F18S17G5
4 名成员
创作了14篇指南
23条评论
There’s nothing blocking the soft roller in mine. I can spin it by hand. Only the regular brush roll spins. Now what?
Keith Sauer - 回复
I have the same problem. The gear that is connected to the motor that spins the soft brush roller is stripped. The shaft spins but the inside of the gear is stripped therefore it doesnt turn the soft brush roller. I cannot find the replacement part
Bill Pucher - 回复
Having this same problem
Keona Taylor -
Same here…no blockage, but won’t spin
tbridge - 回复
I also have the same problem. No blockage. The brush roller works but the soft roller does not spin.
Gina - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 108
总计 10,165
