跳转到主内容
Shark Cordless Pet Perfect Front Motor Replacement
你所需要的
  1. Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: 步骤 1 中的图像 1,2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Belt: 步骤 1 中的图像 2,2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 2 中的图像 1,3 Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 2 中的图像 2,3 Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 2 中的图像 3,3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 3 中的图像 1,3 Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 3 中的图像 2,3 Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 3 中的图像 3,3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 4 中的图像 1,2 Shark Cordless Pet Perfect Front Motor  Replacement: 步骤 4 中的图像 2,2
    • Remove the belt from the motor mount, and then replace with a new belt.
  5. Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: 步骤 5 中的图像 1,2 Shark Cordless Pet Perfect Front Motor  Replacement, Front Motor: 步骤 5 中的图像 2,2
    • Remove the solder from both motor terminals.
结论
3等其他人完成本指南。
Ashley Calkins
于02/02/17注册
560 声望
创作了3篇指南
团队
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G2
4 名成员
创作了11篇指南
2条评论
Well done, Ashley! You might want to note that using a solder remover is helpful.
Jimbo - 回复
Where can I obtain the new motor with the plastic gear?
F V - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,665
