跳转到主内容
Shark Cordless Pet Perfect Battery Replacement
你所需要的
  1. Shark Cordless Pet Perfect Battery Replacement, Battery: 步骤 1 中的图像 1,3 Shark Cordless Pet Perfect Battery Replacement, Battery: 步骤 1 中的图像 2,3 Shark Cordless Pet Perfect Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
    • Using a black spudger pry open the cover, and remove the cover plate.
  2. Shark Cordless Pet Perfect Battery Replacement: 步骤 2 中的图像 1,2 Shark Cordless Pet Perfect Battery Replacement: 步骤 2 中的图像 2,2
    • Once the battery cover is removed slide the battery mount upwards and pull it out.
  3. Shark Cordless Pet Perfect Battery Replacement: 步骤 3 中的图像 1,3 Shark Cordless Pet Perfect Battery Replacement: 步骤 3 中的图像 2,3 Shark Cordless Pet Perfect Battery Replacement: 步骤 3 中的图像 3,3
    • Pull out the battery and then disconnect the battery at the quick disconnects.
结论
3等其他人完成本指南。
Ashley Calkins
于02/02/17注册
560 声望
创作了3篇指南
团队
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G2
4 名成员
创作了11篇指南
4条评论
Throw it away and buy new lithium Pet Perfect
John Carson - 回复
I changed the battery, it still shuts off after 1 second
Garry - 回复
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Ralph E Beaver - 回复
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
Aurel Tita - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 88
总计 14,135
