跳转到主内容
Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement
你所需要的
  1. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement, Hose: 步骤 1 中的图像 1,2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement, Hose: 步骤 1 中的图像 2,2
    • Press the button titled "Hose Release" to detach the hose from the dust cup.
  2. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 2 中的图像 1,2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 2 中的图像 2,2
    • Check the hose and opening on the back of the connector for blockages and remove any that you encounter.
  3. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 3 中的图像 1,2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 3 中的图像 2,2
    • Disconnect the hose attachment in the middle of the wand.
  4. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 4 中的图像 1,3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 4 中的图像 2,3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 4 中的图像 3,3
    • Detach the wand from the floor nozzle by pressing the button titled "Wand Release."
    • Check the opening of the bottom of the wand for blockages and remove any that you encounter.
  5. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 5 中的图像 1,3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 5 中的图像 2,3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 5 中的图像 3,3
    • Detach the handle by pressing the button titled "Handle Release."
    • Check the opening at the top of the wand and the opening of the handle for any blockages and remove any that you encounter.
    • Keep the handle removed from the wand.
  6. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 6 中的图像 1,2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 6 中的图像 2,2
    • Detach the dust cup from the floor nozzle.
  7. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 7 中的图像 1,3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 7 中的图像 2,3 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 7 中的图像 3,3
    • Tilt the floor nozzle downwards.
    • Check the opening of the floor nozzle for blockages and remove any that you encounter.
  8. Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 8 中的图像 1,2 Shark Apex DuoClean Powered Lift-Away AZ1002 Hose Replacement: 步骤 8 中的图像 2,2
    • Check the end of the hose that is not directly attached to the handle for any blockage and remove any that you encounter.
结论
To reassemble your device, follow these instructions in reverse order. You will know when the pieces have reconnected if you hear a "click" sound.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 60
