跳转到主内容
加入维修社区 - 创建账户
Shank Button Replacement
你所需要的
  1. Shank Button Replacement, Shank Button: 步骤 1 中的图像 1,3 Shank Button Replacement, Shank Button: 步骤 1 中的图像 2,3 Shank Button Replacement, Shank Button: 步骤 1 中的图像 3,3
    • Remove your loose button (if necessary).
    • If the button is already missing, remove any loose threads from your garment.
    • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
    询问修复机器人
    添加评论
  2. Shank Button Replacement: 步骤 2 中的图像 1,3 Shank Button Replacement: 步骤 2 中的图像 2,3 Shank Button Replacement: 步骤 2 中的图像 3,3
    • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
    • Thread your needle.
    • Pull the thread until two equal parts are on either side of the needle.
    • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
    询问修复机器人
    添加评论
  3. Shank Button Replacement: 步骤 3 中的图像 1,3 Shank Button Replacement: 步骤 3 中的图像 2,3 Shank Button Replacement: 步骤 3 中的图像 3,3
    • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
    • Pull the thread until the knot rests on the fabric.
    • Insert your needle into the shank on the back of your button.
    • Pull the thread until the button rests on the fabric.
    • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
    询问修复机器人
    添加评论
  4. Shank Button Replacement: 步骤 4 中的图像 1,3 Shank Button Replacement: 步骤 4 中的图像 2,3 Shank Button Replacement: 步骤 4 中的图像 3,3
    • To tie off your thread, insert the needle back into the fabric near your previous stitches.
    • Pull thread until there is a small loop (do not pull flush with fabric).
    • Insert the needle into the thread loop and pull through.
    • Pull the thread until the loop closes and a knot is formed.
    询问修复机器人
    添加评论
  5. Shank Button Replacement: 步骤 5 中的图像 1,3 Shank Button Replacement: 步骤 5 中的图像 2,3 Shank Button Replacement: 步骤 5 中的图像 3,3
    • Trim any excess thread from the button area.
    • Enjoy your newly repaired item!
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
Rebekah Kilpatrick
于09/20/23注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 57
总计 1,067
