跳转到主内容
Sewing a small Hole for a Seamless Fix
你所需要的
  1. Sewing a small Hole for a Seamless Fix, Sewing a small Hole for a Seamless Fix: 步骤 1 中的图像 1,1
    • Ensure the hole is small enough to be easily repaired with sewing.
  2. Sewing a small Hole for a Seamless Fix: 步骤 2 中的图像 1,2 Sewing a small Hole for a Seamless Fix: 步骤 2 中的图像 2,2
    • Thread the needle with a length of thread doubling it over at the end to secure it.
    • At a good length (depending on the size of the hole), cut off the excess and tie a knot at the end of the thread.
  3. Sewing a small Hole for a Seamless Fix: 步骤 3 中的图像 1,1
    • Position the sweater with the hole facing up on a flat surface. Make sure your sweater is inside out.
    • This will make the stitches not as visible.
  4. Sewing a small Hole for a Seamless Fix: 步骤 4 中的图像 1,3 Sewing a small Hole for a Seamless Fix: 步骤 4 中的图像 2,3 Sewing a small Hole for a Seamless Fix: 步骤 4 中的图像 3,3
    • Insert the needle into the fabric slightly above the hole, pulling it through the backside of the sweater, and repeat this process along the edges of the hole to create a series of stitches.
  5. Sewing a small Hole for a Seamless Fix: 步骤 5 中的图像 1,1
    • Continue stitching back and forth across the hole in a zig-zag pattern until it is completely closed, ensuring stitches are tight and secure.
  6. Sewing a small Hole for a Seamless Fix: 步骤 6 中的图像 1,2 Sewing a small Hole for a Seamless Fix: 步骤 6 中的图像 2,2
    • Tie off the thread by creating a small knot at the end of the stitching and trimming any excess thread with scissors.
  7. Sewing a small Hole for a Seamless Fix: 步骤 7 中的图像 1,1
    • Reverse your sweater outside in. Tug at the area slightly to ensure the stitches hold and the fabric remains intact.
终点
Kendra Tejada
于04/22/24注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team A-10, Briggs Spring 2024 CSU Los Angeles, Team A-10, Briggs Spring 2024 的会员
CSULA-BRIGGS-S24SAG10
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 140
