跳转到主内容
修复你的物品
维修的权力
商店
简介
A ladder stitch, or closure stitch, is a sewing technique that allows you to close a tear without leaving the stitching visible.
The trick is to make the stitches as small and as even as possible. This technique works for repairing almost any type of tear.
配件
  1. Thread your needle and tie a knot in the end. We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread. Drive the needle from the back of the material, just before where the tear starts.
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Take a small stitch, going in and out of the material, on one side of the tear only. Pull the thread taut.
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took. Pull the thread taut. This should cinch the material together.
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch. Stitch until you come to the end of the tear.
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible. Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut. Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
终点
2等其他人完成本指南。
Brittany McCrigler
于2012年03月05日注册
85,383 信誉积分
创作了132篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 16
过去的30天: 80
总计 6,955
