跳转到主内容
Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement
你所需要的
  1. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement, PCB (Printed Circuit Board): 步骤 1 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 步骤 2 中的图像 1,1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 步骤 3 中的图像 1,1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 步骤 4 中的图像 1,1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 步骤 5 中的图像 1,2 Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement: 步骤 5 中的图像 2,2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
结论
Mateo Begue
于09/26/12注册
102 声望
创作了2篇指南
团队
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G46
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 1,501
