跳转到主内容
加入维修社区 - 创建账户
Service door disassembly
你所需要的
  1. Service door disassembly, Remove the battery: 步骤 1 中的图像 1,3 Service door disassembly, Remove the battery: 步骤 1 中的图像 2,3 Service door disassembly, Remove the battery: 步骤 1 中的图像 3,3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
  2. Service door disassembly, Remove the captive screw of the service door: 步骤 2 中的图像 1,1
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
  3. Service door disassembly, Remove the service door: 步骤 3 中的图像 1,3 Service door disassembly, Remove the service door: 步骤 3 中的图像 2,3 Service door disassembly, Remove the service door: 步骤 3 中的图像 3,3
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
  4. Service door disassembly, Identify the components: 步骤 4 中的图像 1,1
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
结论
Roberto Bartolacci
于02/10/18注册
1,518 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 19
总计 366
