跳转到主内容
SereneLife Treadmill SLFTRD20 Belt Adjustment
你所需要的
  1. SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 1 中的图像 1,2 SereneLife Treadmill SLFTRD20 Belt Adjustment, SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 1 中的图像 2,2
    • Turn on the main power switch.
  2. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 2 中的图像 1,2 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 2 中的图像 2,2
    • Begin by pressing the "Start" button on the machine.
    • Let the treadmill belt run at the lowest setting.
  3. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 3 中的图像 1,2 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 3 中的图像 2,2
    • In order to locate the roller adjustment bolts, try locating the rear left cover and rear right cover.
  4. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 4 中的图像 1,3 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 4 中的图像 2,3 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 4 中的图像 3,3
    • Remove the attached rear left and right covers from the treadmill.
    • After removing the rear covers, you'll be able to see the adjustment bolts.
  5. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 5 中的图像 1,2 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 5 中的图像 2,2
    • Before we begin it's important to determine which side the belt is shifting towards.
    • If the belt is shifting to the right, then turn the right adjustment bolt to turn 1/4 clockwise. If the belt is shifting to the left, then turn the left adjustment bolt to turn 1/4 clockwise.
    • Place the Allen wrench in the left rear roller bolt.
    • Turn the left roller bolt adjustment to turn one-fourth clockwise.
    • Now stop and wait for the belt to begin to center itself.
    • You must wait for the belt to re-center between each adjustment to ensure that you do not overcorrect the belt.
  6. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 6 中的图像 1,1
    • In order to fix the slipping belt during use, we need to turn off and unplug the Treadmill.
  7. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 7 中的图像 1,3 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 7 中的图像 2,3 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 7 中的图像 3,3
    • Place the Allen wrench in the left roller bolt and turn it 1/4 clockwise to tighten the belt.
    • Repeat on the right side of the roller bolt in the same way.
  8. SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 8 中的图像 1,2 SereneLife Treadmill SLFTRD20 Belt Adjustment: 步骤 8 中的图像 2,2
    • Attach the rear covers onto the left side and right side of the frames.
    • Turn the main power switch back on and run the treadmill at the lowest speed.
    • Run on the treadmill to determine if the belt is still slipping or not.
    • Repeat this procedure until the belt no longer slips.
结论
2等其他人完成本指南。
Alina Abbas
于07/03/21注册
211 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 40
总计 1,790
