简介
This Prerequisite-Only guide shows how to remove the bottom board from the 8BitDo SN30 Pro+
你所需要的
Place the controller face down.
Remove the battery cover.
Remove rechargeable battery or AA batteries.
Remove L2 and R2 trigger buttons by pushing them away from the grips.
在这个步骤中使用的工具:Tweezers$4.99
Use Tweezers to uncover two screws under the label in the battery compartment.
Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
At the end of each grip, pry apart the covers.
Use fingernail or opening pick to undo the two top clips.
One clip next to L button.
One clip next to R button
Undo the final clip between the joysticks.
Carefully move the rear cover away and from the front cover. Place it to the left.
Unlock the ribbon cable by push open the black plastic tab.
Pull the ribbon cable out of the connector in the direction of the cable.
Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
Four around the Right stick
Four around the Left stick
One next to the Battery connector
Pull the two rumble motors out of their housings.
Grab the analog sticks to pull out the circuit board
2等其他人完成本指南。
