跳转到主内容
Separate Samsung SGH-X105 Front & Back Panels
你所需要的
  1. Separate Samsung SGH-X105 Front & Back Panels, Battery: 步骤 1 中的图像 1,1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Separate Samsung SGH-X105 Front & Back Panels: 步骤 2 中的图像 1,3 Separate Samsung SGH-X105 Front & Back Panels: 步骤 2 中的图像 2,3 Separate Samsung SGH-X105 Front & Back Panels: 步骤 2 中的图像 3,3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Separate Samsung SGH-X105 Front & Back Panels, Front & Back Panels: 步骤 3 中的图像 1,1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Separate Samsung SGH-X105 Front & Back Panels: 步骤 4 中的图像 1,3 Separate Samsung SGH-X105 Front & Back Panels: 步骤 4 中的图像 2,3 Separate Samsung SGH-X105 Front & Back Panels: 步骤 4 中的图像 3,3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Separate Samsung SGH-X105 Front & Back Panels: 步骤 5 中的图像 1,2 Separate Samsung SGH-X105 Front & Back Panels: 步骤 5 中的图像 2,2
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
结论
DJ Tarazona
于04/13/10注册
58 声望
创作了3篇指南
团队
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G29
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,848
