跳转到主内容
Sennheiser RS120 Battery Replacement
你所需要的
  1. Sennheiser RS120 Battery Replacement, Ear Pad: 步骤 1 中的图像 1,3 Sennheiser RS120 Battery Replacement, Ear Pad: 步骤 1 中的图像 2,3 Sennheiser RS120 Battery Replacement, Ear Pad: 步骤 1 中的图像 3,3
    • Grip the ear pad with one hand and steady the headset on the other.
    • Twist the ear pad counterclockwise, then lift the ear pad off after about an eighth of an inch of the turn.
    • Replace the old ear pad with a new ear pad.
  2. Sennheiser RS120 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Sennheiser RS120 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Twist the left ear pad counterclockwise to reveal the battery compartment within the headphone.
    • To remove batteries, push inward and lift up.
    • The battery should be able to pop out.
结论
15等其他人完成本指南。
Gayle Dunham
于03/03/10注册
375 声望
撰写一个指南
7条评论
Thanks for the information - this made changing the batteries a snap.
Jim K - 回复
Extremely helpful. Thank you!
-Randy N
Randy - 回复
I own three sets and one quit working. As it turns out that the rechargeable batteries in that one set need replacing.
Until I purchase some rechargeable batteries, I am using standard AAA batteries and just have to remember NOT to put the headset back on the cradle.
Thanks for the info on how to access the batteries !
mcgilljp - 回复
Thanks! You solved my mystery.
Marilyn Carini - 回复
Good information, I wouldn’t have had a clue without it. Many thanks
Geoff Smith - 回复
my kids putin regular batteries did this ruin head set?
judith langley - 回复
how do you know when it's time to replace the rechargeable batteries? The headphones work, but begin to buzz after a bit. The buzz makes listening impossible. Is that the batteries?
kristen rinaker - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 40
过去 30 天: 167
总计 44,582
