跳转到主内容
Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement
你所需要的
  1. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Earmuff: 步骤 1 中的图像 1,1
    • Grab the earmuffs with one hand and hold the headphones with the other.
  2. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pull the earmuff until it separates from headphones as shown.
  3. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the 4 8mm screws with a #000 Philips screw driver.
  4. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the 2 2mm screws using a #000 phillips screwdriver.
  5. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, remove all the wires attached to the motherboard and other components.
  6. Sennheiser Momentum Wireless M2 AEBT Motherboard Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Finally, remove the blue ribbon plugged into the motherboard.
    • Make sure to do this using tweezers, so as to avoid any damage to the fragile ribbon.
结论
nasaintj
于09/08/23注册
159 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 15
过去 30 天: 56
总计 241
